Email server setup
Discussion in '3CX Phone System - General' started by msi, Jan 5, 2013.
  1. msi
    msi
    Dec 2, 2012
    We are getting an error when setting up email
    "Unable to connect to email server"
    Maybe he settings are not correct. We are using an Exchange server.
    What are the correct settings to input under the Mail Server tab ?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
  3. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    Under 'Mail Server' tab:
    We usually just put the local LAN IP address of the SBS/Exchange server in the 'Mail Server' box, then create a reply address e.g. customer3CX@customerdomain.co.uk as the reply address (assuming that the 3CX and mail-server are on the same LAN???).
    We don't usually need to input an SMTP username & password for an exchange server ...
    Under 'E-mail Notifications' tab:
    We create a mail-group in Exchange and use that for the e-mail address input at the top of this page. We can then control distribution of 'Event' messages to customer IT staff as well as ourselves (as the system supplier and maintainer), via the Exchange mail-group and active directory.
    Best regards
