Email Template HTML
Discussion in '3CX Phone System - General' started by Trever, Jan 21, 2017.
  1. Trever
    Jan 17, 2017
    5
    Whenever I am updating and creating my template I have "Learn how to get more out of 3CX at www.3cx.com" added to the bottom of my HTML emails. I would like to remove that. Is it possible to remove that ending? If so, can you please advise on how to do so?
    Thank you
  2. XanthiZ
    3CX Support
    Dec 18, 2015
    46
    7
    Hello Trever,
    Unfortunately there is no way for the customer to remove the text "Learn how to get more out of 3CX at www.3cx.com" from the HTML emails.Its hard coded for all Email Templates.
  3. dab
    dab
    Nov 1, 2009
    67
    Please remove this text. The receivers of these Mails does not need to know how they "can get more out of 3CX", sorry.
    This is something for the admin, but not for endusers, customers, or report receivers.
  4. XanthiZ
    3CX Support
    Dec 18, 2015
    46
    7
  5. dab
    dab
    Nov 1, 2009
    67
