Email Template
Discussion in '3CX Phone System - General' started by mirvine, Dec 12, 2008.
  1. mirvine
    Oct 1, 2008
    5
    Is there any way to change the email template. when i get a voice mail, i would like to know where it come from. i have many did's and it would be great to know. thank you
  2. mirvine
    Oct 1, 2008
    5
    well i know that i cant find it from the UI but where in the code can i find it. i searched many areas and cant find a thing
  3. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Can you please explain the call scenario?
    What do did's have to do with this? You want to know on which incoming DID did the external user contact you? Isn't the caller id enough? What extra information do you need to display / read when a voicemail comes into your voicemail box?
  4. mirvine
    Oct 1, 2008
    5
    What i need to know is from what number they call from, so this way i know if it was important or not, so if they call from the main DID, then i will call back, and if not then ill wait till later
  5. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Yes that is the outbound Caller ID or outgoing Caller ID.
    The guy calling into your system should display it * this is his outbound caller ID.
    Send an invite and explain what you expect to see. I think that you are referring to appending the DID name. This will be available in the next release
