EMAIL?
Discussion in '3CX Phone System - General' started by JDC, Jul 18, 2010.
  1. JDC
    JDC
    Jul 9, 2009
    9
    Hi, still having issues with my email settings, i run ms server 2008 with smtp enabled, no user/pass for the email service.
    i've tested it without a problem outside of 3xc but doesnt ever seem to work with 3cx, anyone else experience this before?
    thanks
  2. carolinainnovative
    May 4, 2009
    369
    5
    What do you have currently as your settings in 3cx? Are you getting an error message? Does anything show up in the (Verbose-mode) logs?
  3. StefanW
    Jun 2, 2009
    1,187
    77
    so you installed the IIS SMTP service on a 2008 server running as well the 3CX PBX.
    Can it be that the host blocks by default requests from local host?
    Try to speak to your SMTP Server via Telnet.
    do this:
    -cmd
    -telnet localhost 25 (then you have set some other host name in your pbx place it in there instead of localhost)
    -hello
    -rcpt to: mye-mail@domain.com
    -data
    [Enter].[Enter]
    bye or quite
    most likely you will fail already at step 2
    but this makes it much more clearer where look next to
  4. JDC
    JDC
    Jul 9, 2009
    9
    I get this response at step 2, however, the rest of the commands are "unrecognized"
    220 WEBSTER Microsoft ESMTP MAIL Service, Version: 7.0.6002.18222 ready at Tue, 20 Jul 2010 15:38:08 -0400
  5. JDC
    JDC
    Jul 9, 2009
    9
    hello
    500 5.3.3 Unrecognized command
    ehlo
    250-WEBSTER Hello [192.168.2.10]
    250-TURN
    250-SIZE 2097152
    250-ETRN
    250-PIPELINING
    250-DSN
    250-ENHANCEDSTATUSCODES
    250-8bitmime
    250-BINARYMIME
    250-CHUNKING
    250-VRFY
    250 OK
  6. JDC
    JDC
    Jul 9, 2009
    9
    Seems to be working. But 3CX doesn't send anything.
    Like I mentioned before, I have a forum setup to use the same SMTP service and that seems to be working.
  7. carolinainnovative
    May 4, 2009
    369
    5
    Instead try:
    hello
    MAIL from <test@3cx.com>
    rcpt to <mye-mail@domain.com>
    data
    [Enter].[Enter]
    quit
  8. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Install logging and see what's going on. The telnet stuff is nonsense and a waste of time in this case especially since it works for your other SMTP services/clients
    Here are the directions:
    1) Install ODBC Logging module (role service in Server Manager)
    2) Stop / Start the SMTP Service
    3) Verify your SMTP service is configured for logging. It's not on by default.
    4) Look at your log folder.
