emailed voicemail attachments as mp3
Discussion in 'Ideas' started by koru, Nov 16, 2015.
emailed voicemail attachments as mp3 5 5 1votes
5/5, 1 vote
  1. koru
    Nov 2, 2015
    currently emailed voicemail attachments don't play via native viewers in gmail or android email apps.
    the voicemail attachment should be a format that will play without using a custom audio app
  2. Brad Allison
    Jun 7, 2017
    67
    20
    agreed, alternative audio format would be beneficial
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    Take a look at our Voicemail Manger. It can send voicemails as MP3 and does many more things too.
