Embedded 3CX (small, fanless and low power usage)
Discussion in '3CX Phone System - General' started by ciscotech2007, Mar 20, 2009.
  1. ciscotech2007
    Jan 27, 2009
    94
    [​IMG]
    [​IMG]
    Anyone out there working on a 3CX server that;
    (a) low power consumption
    (b) ultra-small profile
    (c) good processing speeds, RAM, storage
    (d) fanless :)
    (e) memory card flash-based hard drive
    Note: this solution would not permit using a INTERNAL PCI FXO-to-SIP card, but since they have integrated NICs you can use a Patton or VOIP provider like most 3CX deployments.
    I am currently developing solutions. Could use any feedback.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Don't wasted your time. Use it for Askozia.
  3. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Actually I successfully run 3CX on this board http://www.intel.com/products/desktop/motherboards/D945GCLF/D945GCLF-overview.htm with standard 80 Gb Samsung HDD. I use this case http://www.chenbro.com/corporatesite/products_detail.php?serno=127
    Also you can get this machine http://www.crunchgear.com/2008/11/29/msi-windbox-is-a-vesa-mounts-best-friend/
    Very cool! This is total 3CX embedded solution.
  4. ciscotech2007
    Jan 27, 2009
    94
    1sr, 5qg4. Thank you for your feedback.
    2nd, IGOR, great information. That MSI setup would work nicely! Appears it does not have a SSD (solid state drive) but the form factor is VERY small and it appears to have no fans. I am not sure about the processor though. Intel Atom processor may not be enough power to drive a 3CX system with 2 - 4 extensions with simultaneous calls, voicemails, VOIP trunks, etc.
    Maybe 3CX will chime in on this.
  5. igor.snezhko
    Jan 7, 2008
    668
    7
    THe 3CX server processing most of calls in bypass mode, so the load on the server is minimal. So you can use this PC in relatively large setup. http://sites.google.com/a/3cx.com/3cx-wiki/Home/technical-documentation-dash/media-server
    And if you use only G711 codec, the load is very small also. I prefer HDD, but not SSD, because you can store many voicemail on it, and it cheap. This MSI PC costs under 300$!
    [​IMG]
  6. igor.snezhko
    Jan 7, 2008
    668
    7
    http://www.compactpc.com.tw/ebox-4300.htm
    [​IMG]
  7. leejor
    11,071
    323
    I'm running it on the D945GCLF with 2 gig of memory. There is a small fanless power supply available (not using that yet) the runs off of 12 volts. There is a small fan mounted on the board. Next step is the solid state drive.
  8. ciscotech2007
    Jan 27, 2009
    94
    Good! Good!
    This is the type of discussion I wanted to get started. This solution would be helpful for anyone wanting to run 3CX on a appliance rather than a typical PC with size and noise.
    Keep up the good work. I would like to see any 3CX systems running on micro-appliances or fanless setups!
  9. igor.snezhko
    Jan 7, 2008
    668
    7
    http://www.itx-warehouse.co.uk/Default.aspx
    Complete Systems - Pre Built
    ITX-W11 ITX Warehouse ITX-W11
    VIA EPIA 1.0 GHz, 512MB Ram, 40GB Hard Drive, DVD / CDRW, 10/100 LAN. Our smallest ever system! In Stock £264.95
    (£311.32 inc. vat)
    Buy Now
    ITX-W21 ITX Warehouse ITX-W21
    VIA EPIA 1.2 GHz, 1024MB Ram, 40GB Hard Drive, DVD / CDRW, 10/100 LAN. PCMCIA / CF Readers In Stock £259.95
    (£305.44 inc. vat)
    Buy Now
    ITX-W2B ITX Warehouse ITX-W2B
    Compact fan cooled system. C134 Case, VIA M10000, 512MB, 80GB 5400RPM, CD/R/RW + DVD +/-R. Finished in Black In Stock £288.95
    (£339.52 inc. vat)
    Buy Now
    ITX-W42 ITX Warehouse ITX-W42
    Dual core Intel Atom Powered!!! 2GB RAM, 500GB Hard Drive, Energy efficient. Highly versatile. Could be used as desktop pc or always on 24/7 server. In Stock £279.95
    (£328.94 inc. vat)
    Buy Now
    ITX-W64 ITX Warehouse ITX-W64
    VIA C7 2.0GHz, 1024MB Ram, 160GB Hard Drive, DVD+/-RW, 10/100 LAN. Shipment
    Due
    16 Apr 2009 £279.95
    (£328.94 inc. vat)
    Buy Now
    ITX-W6B ITX Warehouse ITX-W6B
    Extremely quiet, completely fanless, pre-built and tested system with Dual 10/100 LAN - Perfect for use as a firewall. 600MHz Eden Processor, 512MB RAM, 40GB Hard Drive, DVD/CDRW, 4xUSB v2.0, Serial, Parallel, RCA Spdif / TV-out, S-Video port. In Stock £227.95
    (£267.84 inc. vat)
    Buy Now
    RS1-BLK ITX Warehouse RS1-BLK
    Fanless system with 1TB of storage! Ideal as a home server or stylish desktop pc! Gloss Black In Stock £386.14
    (£453.71 inc. vat)
    Buy Now
    RS1-WHT ITX Warehouse RS1-WHT
    Fanless system with 1TB of storage! Ideal as a home server or desktop pc! White In Stock £386.14
    (£453.71 inc. vat)
    Buy Now
    Mini-ITX PC Build Service
    ITX-BUILD ITX Warehouse ITX-BUILD
    Mini-ITX PC Build Service. You choose the components, we assemble and test it for you. In Stock £42.75
    (£50.23 inc. vat)
    Buy Now
    Self Build Kits
    ARTIGO Pico-ITX Builder A1000 VIA ARTIGO
    Self build Pico ITX Kit Shipment
    Due
    16 Apr 2009 £171.12
    (£201.07 inc. vat)
    Buy Now
