Emergency Broadcast/Alert?
Discussion in '3CX Phone System - General' started by Jimstigator, Nov 4, 2013.
  1. Jimstigator
    Dec 21, 2012
    17
    Does anyone use an emergency broadcast add-on, and or something built into 3CX? My company is looking for a way to notify all employees of an event via phone.
    Thanks!
    Jim
    10,360
    226
    This software was recommended, by another user, in one of the other forums, for paging.
    http://www.acrovista.com/bellcommander/sip-version.html
    I'm not sure if will do what you are looking for.
  3. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Why not just a page all group to all phones announcing there is an issue??
  4. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Bardissi's suggestion is correct. Set up a ring group, set ringing strategy to 'Paging' from the ring group properties. Also make sure you specify the paging code in the Settings>>Advanced Settings>> Dial codes tab(default should be *9).
    then dial the paging code and the ring group number to page all phones for example if your ring group number is 800 and your paging code is *9, dial *9800 and you will page all phones simultaneously. If you have any further questions please feel free to let us know.
    Best Regards
