Emergency IVR
Discussion in '3CX Phone System - General' started by MacAodh, Sep 15, 2014.
  1. MacAodh
    Sep 15, 2014
    Hi all,
    Sometimes we have a situation in the office that requires a change on the phone system. When this happens we want a method of changing the phone system to use a different IVR which informs clients we are having an issue currently and prompts them to leave a voice mail.
    It needs to be able to be done by anyone quickly so either dialling a number or running a script would be the preferable solution.
    Anyone have any ideas? We run 3CX on Windows version 10 service pack 1.1
    Thanks!
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Enact the emergency dial code. Put a value into the otherwise empty box.
    We use **9.. meaning **90 will set back to defaults, **91 will set to the standard "in-office" rules, and **92 will set to that emergency dial extension.. tune as you see fit for the behavior.
    Figuring out <code>0 took a bit of work to nail down.. our after-hours rules were not triggering after our office closed..
