Empty Activity log V15 Linux
Discussion in '3CX Phone System - General' started by choimarc, Mar 31, 2017.
  1. choimarc
    Feb 19, 2014
    72
    6
    Since I have upgraded to V15 on linux, I have an empty Activity Log. I have restarted all the services and they came back. However, they have disappeared again. Is there something I need to know about this ? I'm using chrome but I have the same thing in edge and internet explorer.
    Thanks.
    Marco
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Did you make sure that in the activity log, when you click on Filter "search by date" isn't checked and that you're searching ALL EXTENSIONS and ALL CALLS ?
  3. choimarc
    Feb 19, 2014
    72
    6
    Yes, nothing is checked or specified as a filter.
    Thanks.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,486
    358
    Hello @choimarc
    Please try clearing your browser cache (ctrl + F5) and try again. If that does not work please try changing the logging level to a different value then restart services and see if that works for you. You can change the logging level by navigating to Dashboard / Activity log / Settings
    Can you please also mention what service pack you are running?
  5. choimarc
    Feb 19, 2014
    72
    6
    I already tried clearing my brower cache but that didn't do anything. I know restaring the services work but I don't want to restart the pbx each time I want to consult the activity log. I will try changing the logging level.
    Marco
  6. choimarc
    Feb 19, 2014
    72
    6
    I tried changing the logging level and it doesn't work. What does work is restarting the service. But after 1 day, no more logs in the activity logs until I restart the service again. I'm running version 15.0.62928.5 with the 3cx linux image.
  7. bdarcyevans
    Apr 6, 2015
    50
    Today our event log completely cleared as if someone had clicked the Purge button, except no one had done so (I'm the only one with access). We're running 15.5.1694.0 (Debian ISO). New events displayed without any need to reboot server/restart services/change configuration. Very odd.
