enable/ disable option ring my mobile
Discussion in '3CX Phone System - General' started by internetfabriek, Feb 7, 2017.
  1. internetfabriek
    Jun 27, 2016
    We are looking for a way to enable or disable option "ring my mobile" without having to open the web interface. A short dial code you can put in memory or a link programmed under a button would be ideal.
    This way you could enable this state when you are out of office.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    Hello @internetfabriek
    Unfortunately there is no such feature currently. You can post this under the ideas section of this forum so it can be upvoted by users and perhaps get implemented in a future release
