Implemented Enable Internal IP Change
Discussion in 'Ideas' started by Scott Coleman, May 16, 2017.
Implemented Enable Internal IP Change 3.7 5 3votes
3.7/5, 3 votes
  1. Scott Coleman
    Apr 4, 2017
    We are an IT company and we have recently setup 3 3CX servers for remote locations. once they arrived at their final destination they had to be reloaded and a backup restored just to change the internal IP. I feel that this is a bit overkill to just change the internal IP address.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,397
    273
    Perhaps setting up a small router with their IP Scheme would be helpful instead of setting up on your network.
    Simply ask the customer what IP they would like to assign.
  3. Scott Coleman
    Apr 4, 2017
    That's what we have done for now. It just seems a little inconvenient as we also have a network where their IP scheme is about to change due to poor prior network management.
  4. V..
    V..
    Feb 14, 2017
    74
    29
    Hi Scott, while not officially supported the internal IP address can be changed using the advanced parameters table under the settings menu.
    If you search for the IP of the internal interface and change all instances where it occurs you should not have any issues.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,324
    448
    I can guarantee you that if you change the IP this way you will have issues down the road. The only way to change the local IP is by re-installing the system
    Paul Omans likes this.
  6. islandtech
    Jun 19, 2017
    Can you provide example of the issues that might encountered?
  7. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Just don't do it islandtech. Whenever something strange happens you'll always wonder if it's related to that (well I did anyways, that 1 time I did it) and it doesn't really save that much time anyways.
