Enable the rebound option when ring mobile and desktop phone is selected
Discussion in 'Ideas' started by solutionsit, Oct 21, 2015.
  1. solutionsit
    Nov 25, 2014
    62
    5
    If using patton boxes there is no way for the phone system to know if the mobile has been answered or not. So as soon as the patton dials the line for the mobile it is assumed as answered and the desktop stops ringing. If the rebound could be enabled this would allow both to ring side by side with a patton gateway and only when the called party accepts the call is it concidered answered.
  2. solutechnet
    Oct 7, 2009
    6
