Solved Enabling/Disabling Web Client on Large Scale
Discussion in '3CX Phone System - General' started by Shane Farmer, Sep 21, 2017.
  1. Shane Farmer
    May 15, 2017
    20
    Is it possible to enable/disable the web client on a large scale?
    Either for everyone, or just several extensions at once. V15.5 Update 1.
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    228
    17
    Hello @Shane Farmer
    Unfortunately, no. When selecting multiple extensions at once you can make some configurations that applies to all selected, but there is not an option for this.
    Thank you
