Encryption [Relayed from German Forum]
Discussion in '3CX Phone System - General' started by NMN, Oct 27, 2007.
  1. NMN
    NMN
    Oct 24, 2007
    44
    I found this post in the German forum. As it is fairly quite over there, but the question is intriguing, I though I post a translation of it here:
    Original post: http://www.3cx.de/forums/verschlusselung-7.html
    I am sure mschmidt would appreciate any insight and I will gladly translate any answer posted here ... :D
    NMN
  2. FITEC
    Sep 15, 2008
    19
    did you get any info relating SIPS/SRTP?
  3. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    As of the release of V7, 3CX can do SSIP. We are still working on SRTP, however there is no ETA on this.
    As to configuring secure SIP please review http://www.3cx.com/support/Secure-SIP.html .
  4. Darrin
    Mar 10, 2009
    5
    Any chance there's an ETA on the SRTP feature now?
    Also, If we have remote clients using the proxy/tunnel, is there any encryption applied (ie: do we need to employ SSIP/SRTP over the tunnel or is that redundant)?
    Darrin
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Currently, tunnel do not encrypt its traffic, but there's still no Wireshark plugin to extract audio streams out of it.
