End of call Grace Period????
Discussion in '3CX Phone System - General' started by xcguyxc, Nov 19, 2009.
  1. xcguyxc
    Nov 19, 2009
    7
    Is there a way to have an End of Call Grace Period... Where after a Queues call finishes the extension is removed from the queue for per say 30 seconds.
    In our instance its Tech support and we need to finish the call logs / Ticket before the phone rings again.
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Actually there isn't. I hadn't noticed this before. A "wrap up" time needs to be added to the queues page to allow time for an agent to finish data entry or whatever before the next call comes in.
  3. xcguyxc
    Nov 19, 2009
    7
    I am shocked that this was not a standard feature...
