End User Cheat Sheet
Discussion in '3CX Phone System - General' started by mgmache, Jan 9, 2009.
  1. mgmache
    Dec 2, 2008
    12
    I am looking for a cheat sheet for my end users (1 or 2 page). Install is a v7 enterprise.
    How to access vm, create greeting, transfer calls, hold, park, etc....
    I'd have a "reward" for anyone that may have one I can use!!
    we are using aastra 55 and 51 phones....
    thx..
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    You might find some of the info you require on the 3CX Extension manual on http://www.3cx.com/manual/3CXExtensionmanual7/extension.html
    regards
