End User Quick Reference Guide
Discussion in '3CX Phone System - General' started by samford, Feb 2, 2013.
  1. samford
    Feb 7, 2011
    Does anyone know or have a 3CX End User Quick Reference Guide.
    It should would be handy to give out to new installation sites.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    There isn't one that I know of.
    When you indicate a "user" guide this can cover a lot of territory as each install may be somewhat different -
    May be a bridged system, maybe not
    Could use any number of manufacturer's SIP phones and how one does things with the phone will likely differ
    Might use analog phones.
    May have different dialing rules
    New features, methods and phones are evolving all the time.
    and the list goes on.
    I think the issue is that there are a lot of possible combinations and 3CX elects to use the Blog as the how to......just depends on if you are comfortable with your customers accessing same and then being able to find the correct info. In most cases, I think not, they develop a quick & dirty cheat sheet of the basics for their system and make reference to the Blog if so inclined.
