Endpoint Hostname Configuration Option
Discussion in 'Ideas' started by cobaltit, Aug 22, 2017.
Endpoint Hostname Configuration Option 4.7 5 3votes
4.7/5, 3 votes
  1. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,766
    277
    Love the additional provisioning options added with v15.5 Update 1 (SP1). I'd like to see the device hostname be a configurable option. We often have network monitoring tools in place for our installs so it would be nice to be able to see the different extensions by hostname rather than a 100 SIP-T41P devices. I'm thinking maybe have the template default to something sane and then expose the option to override provisioning tab:
    So maybe template default is:
    network.dhcp_host_name = %%%extension_number%% or ext_%%extension_number%% or %%ua%%-%%extension_number%%
    And the template includes an option to override. Or just leave it as-is with the option to define.
