enter audio codec not listed
Discussion in 'Windows' started by mthomas28, Jul 16, 2012.
  1. mthomas28
    Jul 16, 2012
    My VOIP provider only uses g711 audio codec, but that is not listed in the advanced settings as one of the audio codecs that I can choose from. How am I able to add it to the list then select it.
    11,293
    361
    That is the default Codec, in most cases.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    g711 is also PCMU or PCMA
    g711 are 2 of just 7 codecs I see listed under VOIP Provider Advanced settings. pretty hard to miss.
    What options are you showing?
