Entering extension to bypass Digital Receptionist not working
Discussion in '3CX Phone System - General' started by lloydr1l, Oct 27, 2016.
  1. lloydr1l
    Dec 18, 2015
    42
    The process by which a caller can enter an extension number to go directly to an extension is hit or miss. It works, most of the time, but on occasion (frequently) it takes 2-3 times for it to work. The first 2-3 times it will simply replay the greeting again.
    How to I correct this? Thanks in advance!
  2. 12494
    12494 Member
    Apr 16, 2010
    311
    31
    It may be an issue with DTMF. Suggest you look into that.
    Allen
  3. lloydr1l
    Dec 18, 2015
    42
    Thank you for the reply. In what manner would I look at it? At what level, the 3CX system, the gateway, or from the provider? I guess what you are saying, is that as a user enters the 3 digits, the tones are not getting picked up correctly, but where would I correct this?
