Solved Enterprise option
Discussion in '3CX Phone System - General' started by business54, Jun 5, 2017.
  1. business54
    Apr 20, 2016
    68
    12
    I'm quoting a customer the enterprise license as they want to implement off site DR. Do we need one 3CXPSPROFENT32 or two 3CXPSPROFENT32 ?
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi business54,
    Please check the following link on what you need to built your DR 3CX Phone system https://www.3cx.com/docs/failover/ (Active/Standby server) and all configuration that is needed to achieve the redundancy of 3CX Phone system. Kindly note that you need one enterprise license key for fail-over scenario but is better to contact our sales department to give you all the relevant information about your case. Please visit the following link and find your country sales number to contact them. https://www.3cx.com/company/contact/
  3. business54
    Apr 20, 2016
    68
    12
    Thank you
    GiannosC_3CX likes this.
