Enterprise Q and Digital Receptionist not working..
Discussion in '3CX Phone System - General' started by dionh, Jul 20, 2007.
  1. dionh
    Mar 3, 2007
    23
    I have my lines setup to route inbound calls to a Digital Receptionist (8001) however the calls go stright to the Call Queue (8000) and by passes the Digital Receptionist.
    If I dial 8001 from a phone I get the Digital Receptionist prompts.
    Looks like some kind of bug or can I not have both?
    Many thanks
    Dion
  2. dionh
    Mar 3, 2007
    23
    Ok, think I see whats going on now.
    It looks like it defaulting to OUT OF OFFICE HOURS.
    Looking at the SET OFFFICE HOURS under general nothing is ticket so the same setting will apply for BOTH IN OFFICE HOURS AND OUT OF OFFICE HOURS.
    Dion
  3. dionh
    Mar 3, 2007
    23
    Something wrong here for sure; set the office ours from 9:00 to 18:00 and set the routing in office hours to go to DR 8001 and out of hours to end the call. Now the phone system just rings and rings.
    Get a message in the log saying:
    [CM103005] call(15) is rejected : Destination does not exist or is not registered.
    If I uncheck the office hours and set the out of ours route to DR then I get the prompt. So there is a problem with the office hours and routing.
    Dion
  4. dionh
    Mar 3, 2007
    23
    running version 3CX Phone System v3.0.2328.0 the downlaod page states
    that version v3.1.2295 is aval but i am running this download.
    3cxphonesystem31.exe build v3.1.2295 (Enterprise & Free edition)
  5. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hello dionh
    There was some small bug, if I remember correctly with that version regarding the forwarding to DR and in/out of office hours. I am not sure if your issues were related to that small bug.
    In a few days, we should have another version ready that fixes this and certain other small issues.
  6. dionh
    Mar 3, 2007
    23
    Thanks for update, will wait for the updated version.
