ENUM Support?
Discussion in '3CX Phone System - General' started by parkley, Mar 23, 2007.
  1. parkley
    Mar 23, 2007
    Hi.
    When will you add support for ENUM?
    Rgds
    Patrick Arkley
    http://www.say-no.se
  2. 3CXsupport
    3CXsupport New Member
    3CX Support
    Aug 21, 2006
    193
    We do not intend to implement this in the near future.
    Could you please specify the working environment in which you intended to use this?
  3. parkley
    Mar 23, 2007
    My intention is to use some sort of enum lookup function that queries public enum or the e.164 org domain.
    Each outgoing call would use the enum lookup if selected and if it finds a NAPTR it would use that. If it doesn't find anything it would use the VOIP peer.
    Maybe you could also select if you want to failover to the VOIP peer in case of busy or congestion on the NAPTR call.
    Rgds
    Patrick Arkley
