Equipment Search - Pots Converter
Discussion in '3CX Phone System - General' started by AirMax, Nov 29, 2007.
  1. AirMax
    Nov 29, 2007
    8
    I am looking for something that will convert POTS PTSN lines into VoIP on 3CX.
    I have 2 incoming lines which are been phased out of use and will remain as backup services.
    All and any ideas please.
  2. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    You need a FXO adapter and a variety of vendors make these. Often they will bundle them with FXS ports (used for analog handsets). If you google FXO and SIP you'll find a variety of vendors/products.
  3. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I'm using the Grandsteam 4104 with no issues that are reported here. Also AudioCodes MP114 and Patton are supposed to be better.
    Those are my recommendations for 3 price levels.
