[Error:103] Activation of 3CX VAD
Discussion in 'CRM / Helpdesk / App Integration' started by common.lo, Mar 18, 2014.
  1. common.lo
    Mar 18, 2014
    Hi there,
    Sunddely my VAD activation was lost. I was trying to activate my VAD again and it prompts out the below error message.
    "An error occurred trying to activate your license.
    License key belongs to a previous version of this product. Please contact your 3CX reseller to upgrade your license key.
    Original error: License Key Activation Failed License:103
    System: 0"
    I didn't upgrade my VAD so I am not sure what the issue is.
    VAD version: 3.0.3821.0
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi there,
    Are you trying to activate the VAD license in a machine with 3CX Phone System installed?
    Please send me a private message with your license key so I take a look.
    Thanks.
  3. common.lo
    Mar 18, 2014
    Yup, trying to activate VAD.
    Already sent a pm with license key
