Error 1304. Error writing to file: Gizmox.WebGUI.Common.dll
Discussion in '3CX Phone System - General' started by pdow, Nov 19, 2014.
  1. pdow
    Nov 19, 2014
    I wanted to try out the free edition of your software, so I downloaded 3CXPhoneSystem12.exe and ran it and got "Error 1304. Error writing to file: Gizmox.WebGUI.Common.dll. Verify that you have access to that directory."
    Looking at the installation log file, it apparently it's not an access problem:
    According to the registry on this machine, I have the following .NET frameworks installed:
    v2.0.50727 (2.0.50727.5420)
    v3.0 (3.0.30729.5420)
    v3.5 (3.5.30729.5420)
    v4 (4.5.50709)
    v4.0 (deprecated)
    What version of the .NET framework was the gizmox .dll built with?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Re: Error 1304. Error writing to file: Gizmox.WebGUI.Common.
    Hi there,
    Please ensure you are installing the Phone System as admin user, it seems that some dependencies fail to be written in your windows directory.
    Also, ensure you have all .NET updates and windows updates installed prior to install 3CX.
