ERROR 3cx 5.0.3752.0 - trying to add a Provider VOIP
Discussion in '3CX Phone System - General' started by simones181170, Dec 22, 2007.
  1. simones181170
    Dec 4, 2007
    51
    i've made the update to the 5.0.3752.0
    and i try to add a new voip provider and it report an error
    this is the error
    Cannot save Gateway object: ERROR: duplicate key violates unique constraint "gateway_pkey"<br>#0 C:\Programmi\3CX PhoneSystem\Data\Http\functions\fGateway.php(247): safeExec(Object(PDOStatement), 'Cannot save Gat...')<br />
    #1 C:\Programmi\3CX PhoneSystem\Data\Http\gateway_lines_upd.php(859): fGateway::save(Object(oGateway))<br />
    #2 {main}
  2. simones181170
    Dec 4, 2007
    51
    same if i try to add a new outbound rule
    Cannot save Outbound rule object: add range: ERROR: duplicate key violates unique constraint "dnrange2rule_pkey"<br>#0 C:\Programmi\3CX PhoneSystem\Data\Http\functions\fOutboundRule.php(130): safeExec(Object(PDOStatement), 'Cannot save Out...')<br />
    #1 C:\Programmi\3CX PhoneSystem\Data\Http\dialingplan_info.php(99): fOutboundRule::save(Object(oOutboundRule))<br />
    #2 {main}
  3. simones181170
    Dec 4, 2007
    51
    backup and restore and now it works
    maybe there is a bug for the upgrade
