error: 3cx v5 status problem after call transfer
Discussion in '3CX Phone System - General' started by carmico, Dec 14, 2007.
  1. carmico
    Oct 11, 2007
    23
    Hi.
    3cx v5 with thomson st2030 (supervised line - blf activated)
    when i receive a call from outside to a ringing group (all extensions rings) and then make a call transfer to another extension in the 3cx admin interface line status the extension that make the call transfer remains in Status: Ringing (orange color).
    logs from 3cx server status:
    16:16:08.406 Call::Terminate [CM503008]: Call(1): Call is terminated
    16:16:08.390 LineCfg::getInboundTarget [CM503010]: Inbound office hours' rule for LN:10000 forwards to DN:800
    16:16:00.500 CallLeg::eek:nFailure [CM503003]: Call(1): Call to sip:130@192.168.0.100:5060 has failed; Cause: 302 Moved Temporarily; from IP:192.168.0.130
    16:16:00.500 CallLeg::addRedirection [CM503004]: Call(1): Calling: Ext:Ext.120
    16:16:00.500 CallLeg::addRedirection [CM503006]: Call(1): Diverted to: [sip:120@192.168.0.100:5060;user=phone]
    16:15:54.015 CallCtrl::eek:nAnsweredCall [CM503002]: Call(1): Alerting sip:120@192.168.0.120:5060;user=phone
    16:15:54.000 CallCtrl::eek:nAnsweredCall [CM503002]: Call(1): Alerting sip:130@192.168.0.130:5060;user=phone
    16:15:53.921 MediaServerReporting::SetRemoteParty [MS210002] C:1.3:Offer provided. Connection(transcoding mode): 192.168.0.100:7434(7435)
    16:15:53.906 MediaServerReporting::SetRemoteParty [MS210002] C:1.2:Offer provided. Connection(transcoding mode): 192.168.0.100:7432(7433)
    16:15:53.890 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(1): Calling: RingAll:800@[Dev:sip:120@192.168.0.120:5060;user=phone, Dev:sip:130@192.168.0.130:5060;user=phone]
    16:15:53.875 MediaServerReporting::SetRemoteParty [MS210000] C:1.1:Offer received. RTP connection: 212.97.59.91:44736(44737)
    16:15:53.875 Line::printEndpointInfo [CM505003]: Provider:[MessageNet SmartNumber VoIP IN] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [alpha] Transport: [sip:192.168.0.100:5060]
    16:15:53.875 LineCfg::getInboundTarget [CM503010]: Inbound office hours' rule for LN:10000 forwards to DN:800
    16:15:53.828 CallCtrl::eek:nIncomingCall [CM503001]: Call(1): Incoming call from 347xxxxx@(Ln.10000@SmartNumber VoIP IN) to [sip:800@192.168.0.100:5060]
    16:15:53.609 LineCfg::getInboundTarget [CM503010]: Inbound office hours' rule for LN:10000 forwards to DN:800
    regards,
    Carlo
    ps. if i verify others errors i will post it in the forum. 3cx is a really nice solution. I like it. So we have to participate to make it more powerful & stable.
  2. carmico
    Oct 11, 2007
    23
    the problem verifies only if i make the call transfer to extension without answer the call.
    if i answer the call first, and then make the call transfer to another extension there's no problem.
  3. carmico
    Oct 11, 2007
    23
    no one with an idea ?
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    We're still working on BLF, so bugs are expected :)
