Error 403 - Forbidden
Discussion in 'Windows' started by diogorjsmao, Jul 20, 2014.
  1. diogorjsmao
    Jul 20, 2014
    Hi, I'm New here.
    I'm having this problem: when i try to connect a remote extension, doesn't matter if its on iphone or windows, ir registers, receive calls, but cannot make internal or external calls. In the extetions, we have the error 403 - forbidden.
    Can Anybody Help?
    in the server activity log:
    20-jul-2014 18:37:54.725 [CM502001]: Source info: From: "Dir. Financeiro"<sip:8112@marmovidro.dyndns.info>;tag=EBB0296F25936F3EBF761BA9B81AD92D; To: <sip:*777@marmovidro.dyndns.info>
    20-jul-2014 18:37:54.725 [CM503013]: Call(C:1): Incoming call rejected, caller is unknown; msg=Ivite-IN Recv Req INVITE from 187.2.159.194:3098 tid=mzCUiezSExJO9TcC Call-ID=AF38CC904032D9CD9D0499F4AA7BB96DD449D970:
    INVITE sip:*777@marmovidro.dyndns.info SIP/2.0
    Via: SIP/2.0/UDP 187.2.159.194:3098;branch=z9hG4bKmzCUiezSExJO9TcC;rport=3098
    Max-Forwards: 70
    Contact: <sip:8112@187.2.159.194:3098;rinstance=AB7DA967>
    Call-ID: AF38CC904032D9CD9D0499F4AA7BB96DD449D970
    CSeq: 2 INVITE
    Allow: OPTIONS, INVITE, ACK, REFER, CANCEL, BYE, NOTIFY
    Content-Type: application/sdp
    Proxy-Authorization: Digest username="8112",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:*777@marmovidro.dyndns.info",nonce="414d535c09dcd5c258:341cda65112d034701204791e3f6419b",response="42251cd5c08f8e8b8ac862a2cd04b262"
    Supported: replaces, path
    User-Agent: Acrobits Softphone/5.5
    Content-Length: 428
    v=0
    o=- 3400227106 35267 IN IP4 172.138.170.170
    s=smdbjrs
    c=IN IP4 187.2.159.194
    t=0 0
    m=audio 45798 RTP/AVP 0 8 9 106 105 102 3 101
    a=rtpmap:101 telephone-event/8000
    a=rtpmap:102 iLBC/8000
    a=rtpmap:105 OPUS/48000/2
    a=rtpmap:106 OPUS/48000/2
    a=fmtp:101 0-15
    a=fmtp:102 mode=20
    a=fmtp:105 maxplaybackrate=8000;useinbandfec=1;usedtx=1
    a=fmtp:106 maxplaybackrate=16000;useinbandfec=1;usedtx=1
    a=ptime:20
    a=sendrecv
    20-jul-2014 18:37:54.381 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Invite-UNK Recv Req INVITE from 187.2.159.194:3098 tid=scpKPmWeHpqnLcWF Call-ID=AF38CC904032D9CD9D0499F4AA7BB96DD449D970:
    Via: SIP/2.0/UDP 187.2.159.194:3098;branch=z9hG4bKscpKPmWeHpqnLcWF;rport=3098
    Max-Forwards: 70
    CSeq: 1 INVITE
    Content-Length: 428
    v=0
    s=smdbjrs
    t=0 0
    a=fmtp:101 0-15
    a=fmtp:102 mode=20
    a=ptime:20
    a=sendrecv
    10,368
    228
    Probably because you don't have marmovidro.dyndns.info set as the Domain Name in 3CX.
