Error-404 Not Found
Discussion in '3CX Phone System - General' started by rkcollaborative, Oct 12, 2007.
  1. rkcollaborative
    Oct 12, 2007
    Can someone please help me? I am receiving the following error message when attemping to make a call.
    404 Not Found - wrong number or remote party not online
    I do not have any rules set up for outbound calling; the number I am attempting to call is dialed as: xxx-xxx-xxxx
  2. Ryandc
    Aug 13, 2007
    70
    You HAVE to have a rule set up for outbound calls so that 3cx knows if the call is internal or going out a gateway, and if it is going out a gateway, which gateway to use (that's the whole purpose of VOIP PBX's, I thought-- to make sure every call you make is cheap as can be).
    Set up an outbound rule, and you should be fine.
