Error adding DID
Discussion in '3CX Phone System - General' started by clivecarter332, Mar 8, 2007.
  1. clivecarter332
    Oct 16, 2006
    Just installed the latest version
    Trying to add a DID I got the following error
    Now I get a script error whenever I click on Lines/Manage
    Any ideas what I have done wrong ?
  2. TheSkySpy
    Mar 9, 2007
    Call to a member function getType() on a non-object
    Great. I just activated a DID and am trying to set it up and am getting the exact same problem. Anyone fix this?
  3. vadim
    Aug 17, 2006
    9
    Thanks a lot. It's ours bug. We'll fix it soon. But if you want use it now, don't use "Anywhere" in section "Source device". Or you can apply fix, which i've sent in PM.
