Error Codes
Discussion in 'CRM / Helpdesk / App Integration' started by rcolombo, Jul 19, 2016.
  1. rcolombo
    Jun 20, 2016
    5
    Hello there,
    i'm currently developing an IVR for my business, and i'm debugging it daily. Every now and then i get some errors, and i go looking by the log file "3CXIvrServer.txt", in which i get some error codes. Is there any place i can find those codes and what they means?
    Thank you in advance,
    Roberto
  2. rcolombo
    Jun 20, 2016
    5
    More in detail for this particular case, the error i get is the following:
    12:21:58.216|8456|(0):Error! Module '3CX.com.vxi'. Error ID 212.
    12:21:58.219|8456|api\VXIFactory.cpp(330):IvrDll, VXISessionImpl::processDocument(), Error! VXIinterpreter->Run() failed, error code -100
    12:21:58.219|8456|VXIMachine.cpp(55):IvrDll, VXISessionThread::Run(), Error! Call 'From_xxx_To_xxx_Menu_854_#0/239': session finished with error code -57. Error of document interpretation: -57, interp.code: -100
  3. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,254
    97
    Hi Roberto,
    The description "Error of document interpretation" might be related to a bug fixed some time ago, caused by document encoding. The latest version of the VAD creates the output in UTF-8 format, and that avoids problems with special characters. Are you using the latest VAD to build this app? Can you check if from the About dialog? The latest version is 14.0.4141.
    Kind regards.
  4. rcolombo
    Jun 20, 2016
    5
    Hello, i checked the version and it's the latest as you said. The problem occurs after that a prompt named "bye.wav" has been registered. From that point on the workflow stops and in the log it gives me that error
    Here is the full log of the call:
    Code:
    12:21:00.090|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\welcome.wav
    12:21:00.290|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\codiceutente.wav
    12:21:00.295|8456|VXIMachine.cpp(1072):IvrDll, CallSession::Prompts_Play(), Play Queued files
    12:21:26.103|8456|VXIMachine.cpp(1108):IvrDll, CallSession::Prompts_Stop(), Stop playback
    12:21:30.596|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\1.wav
    12:21:30.679|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\5.wav
    12:21:30.727|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\3.wav
    12:21:30.771|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\6.wav
    12:21:30.814|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\4.wav
    12:21:30.857|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\7.wav
    12:21:30.912|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\9.wav
    12:21:30.959|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\6.wav
    12:21:31.015|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\1.wav
    12:21:31.101|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\confermaDati.wav
    12:21:31.137|8456|VXIMachine.cpp(1072):IvrDll, CallSession::Prompts_Play(), Play Queued files
    12:21:40.203|8456|VXIMachine.cpp(1108):IvrDll, CallSession::Prompts_Stop(), Stop playback
    12:21:41.984|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\lettura.wav
    12:21:42.004|8456|VXIMachine.cpp(1072):IvrDll, CallSession::Prompts_Play(), Play Queued files
    12:21:48.523|8456|VXIMachine.cpp(1108):IvrDll, CallSession::Prompts_Stop(), Stop playback
    12:21:50.035|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\4.wav
    12:21:50.082|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\5.wav
    12:21:50.124|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\2.wav
    12:21:50.166|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\3.wav
    12:21:50.229|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\confermaDati.wav
    12:21:50.246|8456|VXIMachine.cpp(1072):IvrDll, CallSession::Prompts_Play(), Play Queued files
    12:21:57.623|8456|VXIMachine.cpp(1108):IvrDll, CallSession::Prompts_Stop(), Stop playback
    12:21:58.185|8456|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Instance1\Data\Http\Interface\ivr\GasTEL_Debug_153\bye.wav
    12:21:58.219|8456|api\VXIFactory.cpp(330):IvrDll, VXISessionImpl::ProcessDocument(), Error! VXIinterpreter->Run() failed, error code -100
    12:21:58.219|8456|VXIMachine.cpp(55):IvrDll, VXISessionThread::Run(), Error! Call 'From_6342_To_854_Menu_854_#0/239': session finished with error code -57. Error of document interpretation: -57, interp.code: -100
    Just before the prompt i do an insert into a DB, which goes completed successfully.
    Hope you can help me,
    Roberto
  5. edossantos
    Jun 27, 2007
    1,254
    97
    Can you check the file format? The files need to be WAV, PCM, 8KHz, 16 bits per sample, mono. If the format is different you need to change it to the required format.
  6. rcolombo
    Jun 20, 2016
    5
  7. edossantos
    Jun 27, 2007
    1,254
    97
    Can you send me a zip with your VAD project in a private message so I take a look?
