Error debugging in a for loop?
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Jan 5, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I'm finding that after successfully deploying an application with a for loop, stepping through a debug session will only go through the for loop once even though it successfully goes through the loop properly on the actual phone call itself.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    We'll verify this and fix it if we have a bug here.
    Thanks,
  3. VAD_Support
    Aug 6, 2009
    690
    Thanks for the bug report, the fix will be included in the next release.
