- Joined
- Jul 22, 2009
- Messages
- 2
- Reaction score
- 0
hi i have just installed 3cx voip phone,3cx voip phone system and 3cx gateway for skype, i live in france and have a phoneline supplied by my isp Neuf using adsl . i want to make calls using existing phone line, from my computer, i have installed all and configered all as per instructions ,so far i have got to ( phone online status is available) and (phone is now connected) but when i dial a local number i get the message( destination not found) also dial and ring tone appear to be english. software appears to be good if i can make it work, can anyone help ? thanks in advance
15:47:21.968 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.23:5060
15:27:21.750 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.23:5060
15:07:21.609 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.23:5060
14:51:33.187 [CM504002]: Ext.100: a contact is unregistered. Contact(s): [sip:[email protected]:3486;rinstance=519a873b8c5a008e/100]
14:47:21.531 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.23:5060
14:45:02.843 [CM504002]: Ext.100: a contact is unregistered. Contact(s): [sip:[email protected]:3317;rinstance=631e778a6eb1f0a5/100, sip:[email protected]:3486;rinstance=519a873b8c5a008e/100]
14:29:30.765 [CM503008]: Call(18): Call is terminated
14:29:30.750 [CM503015]: Call(18): Attempt to reach <sip:[email protected]:5060> failed. Reason: Not Found
14:29:30.750 [CM503014]: Call(18): No known route to target: <sip:[email protected]:5060>
14:29:30.734 [CM503010]: Making route(s) to <sip:[email protected]:5060>
14:29:30.734 [CM505001]: Ext.100: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.6288.0] Transport: [sip:127.0.0.1:5060]
14:29:30.718 [CM503001]: Call(18): Incoming call from Ext.100 to <sip:[email protected]:5060>
14:28:56.656 [CM503008]: Call(17): Call is terminated
14:28:56.656 [CM503015]: Call(17): Attempt to reach <sip:[email protected]:5060> failed. Reason: Not Found
14:28:56.656 [CM503014]: Call(17): No known route to target: <sip:[email protected]:5060>
14:28:56.640 [CM503010]: Making route(s) to <sip:[email protected]:5060>
14:28:56.640 [CM505001]: Ext.100: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.6288.0] Transport: [sip:127.0.0.1:5060]
14:28:56.625 [CM503001]: Call(17): Incoming call from Ext.100 to <sip:[email protected]:5060>
14:28:48.312 [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:[email protected]:3034;rinstance=1dec4b07f6c0f761/100, sip:[email protected]:3317;rinstance=631e778a6eb1f0a5/100, sip:[email protected]:3486;rinstance=519a873b8c5a008e/100]
14:28:47.140 [CM504002]: Ext.100: a contact is unregistered. Contact(s): [sip:[email protected]:3034;rinstance=1dec4b07f6c0f761/100, sip:[email protected]:3317;rinstance=631e778a6eb1f0a5/100]
14:28:46.640 [CM504002]: Ext.100: a contact is unregistered. Contact(s): [sip:[email protected]:3034;rinstance=1dec4b07f6c0f761/100, sip:[email protected]:3317;rinstance=631e778a6eb1f0a5/100]
14:27:21.406 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.23:5060
14:24:42.546 [CM503008]: Call(16): Call is terminated
14:24:42.546 [CM503015]: Call(16): Attempt to reach <sip:[email protected]:5060> failed. Reason: Not Found
14:24:42.546 [CM503014]: Call(16): No known route to target: <sip:[email protected]:5060>
14:24:42.531 [CM503010]: Making route(s) to <sip:[email protected]:5060>
14:24:42.531 [CM505001]: Ext.100: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.6288.0] Transport: [sip:192.168.1.23:5060]
14:24:42.515 [CM503001]: Call(16): Incoming call from Ext.100 to <sip:[email protected]:5060>
14:24:16.796 [CM503008]: Call(15): Call is terminated
14:24:16.781 [CM503015]: Call(15): Attempt to reach <sip:[email protected]:5060> failed. Reason: Not Found
14:24:16.781 [CM503014]: Call(15): No known route to target: <sip:[email protected]:5060>
14:24:16.781 [CM503010]: Making route(s) to <sip:[email protected]:5060>
14:24:16.765 [CM505001]: Ext.100: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.6288.0] Transport: [sip:192.168.1.23:5060]
14:24:16.765 [CM503001]: Call(15): Incoming call from Ext.100 to <sip:[email protected]:5060>
14:24:12.031 [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:[email protected]:3034;rinstance=1dec4b07f6c0f761/100, sip:[email protected]:3317;rinstance=631e778a6eb1f0a5/100, sip:[email protected]:3398;rinstance=c6f2b4a4a8c3dbaa/100]
14:22:48.812 [CM503008]: Call(14): Call is terminated
14:22:48.812 [CM502001]: Source info: From: "mike.dean57"<sip:[email protected]:5060>;tag=b949cf07<sip:[email protected]:5060>
14:22:48.812 [CM503013]: Call(14): Incoming call rejected, caller is unknown; msg=SipReq: INVITE [email protected]:5060 tid=911f5c327e27190a cseq=INVITE [email protected]:3336 / 2 from(wire)
14:22:21.140 [CM503008]: Call(13): Call is terminated
14:22:21.140 [CM502001]: Source info: From: "mike.dean57"<sip:[email protected]:5060>;tag=69025a10<sip:[email protected]:5060>
14:22:21.140 [CM503013]: Call(13): Incoming call rejected, caller is unknown; msg=SipReq: INVITE [email protected]:5060 tid=9f34c85ad653f45a cseq=INVITE [email protected]:3336 / 2 from(wire)
14:22:07.625 [CM503008]: Call(12): Call is terminated
14:22:07.625 [CM502001]: Source info: From: "mike.dean57"<sip:[email protected]:5060>;tag=373fbb21<sip:[email protected]:5060>
14:22:07.625 [CM503013]: Call(12): Incoming call rejected, caller is unknown; msg=SipReq: INVITE [email protected]:5060 tid=8e21634e832b2613 cseq=INVITE [email protected]:3336 / 2 from(wire)
14:21:17.562 [CM503008]: Call(11): Call is terminated
14:21:17.562 [CM503015]: Call(11): Attempt to reach <sip:[email protected]:5060> failed. Reason: Not Found
14:21:17.562 [CM503014]: Call(11): No known route to target: <sip:[email protected]:5060>
14:21:17.546 [CM503010]: Making route(s) to <sip:[email protected]:5060>
14:21:17.531 [CM505001]: Ext.100: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.6288.0] Transport: [sip:192.168.1.23:5060]
14:21:17.531 [CM503001]: Call(11): Incoming call from Ext.100 to <sip:[email protected]:5060>
14:21:12.531 [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:[email protected]:3034;rinstance=1dec4b07f6c0f761/100, sip:[email protected]:3317;rinstance=631e778a6eb1f0a5/100]
