Error during installation of 3CX Plugin
Discussion in 'CRM / Helpdesk / App Integration' started by ulasozcelik, Jan 27, 2018.
  1. ulasozcelik
    Sep 29, 2009
    OS: Windows 7 Pro 32bit
    I've pre-installed the Microsoft C++ 2010 SP1 + 2015 SP2 + the most recent version of 3CX Windows Client. When I try to install the most recent version of 3CX Plugin, I get the following error:
    Please advise - thanks!
  2. Anh Luong
    Jan 29, 2018
    Im using Win 10 64bit ok
  3. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,354
    108
    Hello @ulasozcelik,
    TAPI is only available in 64 bits operating systems, that's why you get that error.
    Kind regards.
    Ernesto.
  4. ulasozcelik
    Sep 29, 2009
    Oh no! Is there anyway to make it work on a 32bit OS? We'll be running it inside a VDI environment and it's impossible to switch the golden image to a 64bit OS just to accommodate this TAPI incompatibility.
    #4 ulasozcelik, Feb 10, 2018
  5. edossantos
    Jun 27, 2007
    1,354
    108
    If you need the single line TAPI, then please send me a private message and I will give you instructions. Multiline TAPI only works in 64 bits operating systems...
    The single line TAPI will only let you make outbound calls for a single 3CXPhone instance running in the machine. So if you have many agents in different terminal server sessions running 3CXPhone, then this will not be a solution for you. But if you have a single user, then I can give you a solution.
  6. Alexander Walden
    Mar 6, 2018
    i have a similar Problem on my Win 7 32 bit. The Installation of the Tapi-Driver dosent work. Please send me the solution. We are all Single user.
  7. edossantos
    Jun 27, 2007
    1,354
    108
    Hello @Alexander Walden,
    Please send me a private message with your email address, so I can contact you back.
    Kind regards.
