Error during VOIP provider configuration
Discussion in '3CX Phone System - General' started by AndreaL, Jan 29, 2009.
  1. AndreaL
    Apr 24, 2008
    12
    I am using the last version (7) of pbx.
    When i configure a new voip provider (checking the general provider radio button), after inserting the voip data i have the following error: Object instance not set.
    Then it's impossible to configure my provider.
    Thanks, Andrea
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    Try to go to the services status on the 3CX configuration and see if you can stop and start any one of the services.
    Please go under the Computer management -> Local users and Groups -> Users and open the properties of the account ASPNET. Ensure that this account is a member of the Administrators group.
    retry after doing this.
    regards
  3. sipero
    Dec 24, 2008
    12
    Not sure whether this is linked but I get an error as follows An exception occurred EditVoipProvider Error: Object reference not set to an instance of an object.
    Jonathan Hamon
  4. AndreaL
    Apr 24, 2008
    12
    Yes, the error is the same, and it appears at hte 3rd input mask (on voip accoiunt details), when a press NEXT button.
    The 3cx is running under windows vista enterprise SP1 and i configure the system by remote desktop.
    Adding IIS_USERS to administrators group does not solve the prblem.
    Please, help.
  5. nb
    nb Support Team
    Jun 7, 2007
    2,127
    152
    this is a problem from backup and restore.
    Did you use a backup from Version 6.0?
    Note backups from version 6.0 are not supported. You have to install 6.1, restore that backup, make a backup from 6.1 and then restore it on 7.
  6. AndreaL
    Apr 24, 2008
    12
    No.
    Yesterday i removed all 3cx installation and run installation checker.
    I delete completly the 3xc directory under c:\program files
    I reinstall the 3cx software and i put manually all the internals and pstn gateways
    But when i try to insert the generic voip provider i have an error.
    Is it possible to insert it manually into the database
  7. nb
    nb Support Team
    Jun 7, 2007
    2,127
    152
    How many digits do you have in your PBX?
  8. AndreaL
    Apr 24, 2008
    12
