Error: Event log is full
Discussion in '3CX Phone System - General' started by stevebouffe, Dec 20, 2010.
  1. stevebouffe
    Dec 20, 2010
    6
    I've just performed an upgrade from v6 to v9.
    Today I can not start the windows management console. Get an error message
    "An error occured while launching/running the application. Error: The event log is full"
    "Stack Trace : as System.Diagnostice.EventLog.InternalWriteEvent(UInt32 ......... etc"
    Then lots of other data
    Cant see anywhere to clear the logs
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    408
    8
    Re: Windows Management Console Not Starting
    Hi, is it possible to send us a full screen shot of the error. We cant know what etc means.
  3. stevebouffe
    Dec 20, 2010
    6
    Here you go
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    The error is indicating you have reached you max event log size allowance please follow these steps to clear them out.
    1.Open Server Explorer, and then expand the node for the server on which the event log you want to clear resides. For more information, see How to: Access and Initialize Server Explorer/Database Explorer.
    2.Expand the Event Logs node. You will see a list of the three main event logs — Application, Security, and System.
    3.Right-click the log node you want to clear, and then click Clear Event Log.
    4.Click Yes when prompted to confirm the deletion.
  5. stevebouffe
    Dec 20, 2010
    6
