Error handling
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Oct 20, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    When catching an exception, I'm logging the error to the database in the error handling workflow.
    However none of the project error variables are available when I try to select the variables I want.
    What I'd like to do is get those errors so I can log them.
    I want to also trap the exception messages returned from custom code components.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Variables project$.CurrentErrorName$ and project$.CurrentErrorDescription$ are added by the debugger, and are only available in the debug window. You can not use those variables in the callflow.
    Unfortunately there is no way to get that information in the callflow in current version. We may add it in future releases. Until then, if you want to use it for external code execution, maybe an option could be catch the error inside the component and return it as an output parameter or return value.
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Yes, that is possibility. Thanks.
  4. VAD_Support
    Aug 6, 2009
    690
    The latest version of the VAD allows quering those variables in runtime (and not only in the debug window).
    So, now you can know the cause of the error, and log it to a database or whatever you need...
    Thanks for your feedback!
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Perfect, thank you.
