error I need help
Discussion in 'Windows' started by wisecomputers, Jun 11, 2008.
  1. wisecomputers
    wisecomputers New Member
    Apr 24, 2008
    126
    Ok, I now have V6 RC1, and I still can not add an extension. Any help would be great. I need to get this fixed ASAP.
    Object duplication error
    Click here to see the detailed error description.
    Cannot save User object: ERROR: duplicate key violates unique constraint "users_pkey"<br>#0 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fUser.php(56): safeExec(Object(PDOStatement), 'Cannot save Use...')<br />
    #1 C:\Program Files\3CX PhoneSystem\Data\Http\user_extension_info.php(1129): fUser::save(Object(oUser))<br />
    #2 C:\Program Files\3CX PhoneSystem\Data\Http\functions\gui\fmPage.php(70): aOnOk->execute()<br />
    #3 C:\Program Files\3CX PhoneSystem\Data\Http\functions\gui\fmPage.php(85): fmPage->processData()<br />
    #4 C:\Program Files\3CX PhoneSystem\Data\Http\functions\gui\fmPageEx.php(110): fmPage->toHTML()<br />
    #5 C:\Program Files\3CX PhoneSystem\Data\Http\user_extension_info.php(1183): fmCustomPage->toHTML()<br />
    #6 {main}
  2. wisecomputers
    Apr 24, 2008
    126
    6.0.546.0 is the newest, and it does not fix it with that.
  3. wisecomputers
    Apr 24, 2008
    126
    I am hoping for a better solution, Nick do you have any ideas?
