Error in Beta 2
Discussion in '3CX Phone System - General' started by ace, Oct 4, 2006.
  1. ace
    ace
    Oct 4, 2006
    5
    After I added a VOIP-provider and tried to check Line Status I get the following error under External lines:
    Fatal error: Call to a member function getNumber() on a non-object in C:\Program Files\3CX\PhoneSystem\Data\Http\status.php on line 195
    I don't know if this can also be the reason for outbound calling not working, however I do see the message Line [*******] has been registered at provider in Server status
    **** I have removed this for privacy.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    Error might be at VOIP provider
    What VOIP provider are you using? Is it one of the ones we have tested with? We have already encountered some VOIP providers that are not SIP standard conform.
  3. ace
    ace
    Oct 4, 2006
    5
    Provider I am using is voipbuster.
