error in translation fr on voicemail
Discussion in '3CX Phone System - General' started by bluetel2, Jul 12, 2010.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    Hi all,
    like previous version it exist an error when user want to connect to voicemail. in french voicemail said "veuillez saisir PIN, maintenant appuyer sur #" in english it's like -> "type your PIN, now press #"
    but it must be "type your PIN, next press #" in french "veuillez saisir code PIN, ensuite appuyez sur #"
  2. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Hi, we uploaded the new prompt sets for french. You can download them.
    Also can you tell me if this issue is still there.
    Thanks and Regards
  3. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    it's the same error, their is no change since last prompt set.
  4. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    i do an update of this post because error in translation exist too.
    tks
