Error installing client on Vista
Discussion in 'Windows' started by mishmosh1970, Oct 27, 2008.
  1. mishmosh1970
    Oct 27, 2008
    Has anyone run into Error Code 2755 when trying to install the v6 client on Vista (32-bit)? It won't go any further. I'm able to install on my XP partition from the same msi.
  2. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    Yes, same error on two different Vista (32 bit, Ultimate) PCs. No luck at all.
  3. epiraino
    Oct 29, 2008
    Same error on Vista, :roll:
  4. Sepp
    Jul 7, 2008
    21
    HI,
    try this, disable UAC , make a new install and the re-enable UAC.
    should do the trick
    Sepp
  5. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    Yes, it did.
    Any comment from 3CX on this issue?
  6. epiraino
    Oct 29, 2008
    Sorry what is UAC.. Thanks
  7. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello
    http://www.laboratoire-microsoft.org/tips-23933-desactiver-uac-vista.html
  8. mtaino
    Nov 16, 2008
    Instead of disabling/enabling UAC (for which you need 2 reboots) you can try to launch cmd.exe in elevated mode and then launch installer using msiexec /i yourapp.msi. This works for sure, beacuse I used it yesterday, you don't need to reboot and, most of all, you can use also with other apps that might have the same problem.
    Bye
    Max
