Solved Error: Interface 3CX With Bitrix24
Discussion in 'CRM / Helpdesk / App Integration' started by sang, Jun 9, 2017.
  1. sang
    Feb 22, 2017
    15
    hi everyone
    I have a problem when interface 3cx with Bitrix24
    [​IMG]
    when i click Authorize Plugin - in it show:
    [​IMG]
    I think it ok but when i closed this popup it shown:
    [​IMG]
    so I can't interface them . Please help me
    i try to some another account bitrix24, so it can't interface
    Thanks everyone
    #1 sang, Jun 9, 2017
  2. Andreas Paradisiotis
    Apr 7, 2017
    53
    11
    Hello sang
    Are you using self hosted Bitrix24 or cloud ?
  3. sang
    Feb 22, 2017
    15
    I'm using bitrix on cloud . before update 15.5 i popuped it in version 15 . but when i update 15.5 i have this error. Please help me
    #3 sang, Jun 10, 2017
  4. sang
    Feb 22, 2017
    15
    please help me ....
  5. Andreas Paradisiotis
    Apr 7, 2017
    53
    11
    Bitrix24 plugin is tested on 15.5 and works as expected. I send you a pm
  6. sang
    Feb 22, 2017
    15
    hi Andreas
    Thanks for your help
    I want ask a question. I hop you can help me
    1. 3CX Interface with Bitrix24 On Premise ( self-hosted) ???
    i had read the document of Interface 3CX with Bitrix24 , it wrote :
    • A Bitrix24 account (Cloud version , Self hosted Version with REST API enabled)
    . if it can interface with Self hosted Version, i hope you can send me a document interface with Self Hosted
    thanks you
  7. Andreas Paradisiotis
    Apr 7, 2017
    53
    11
    Hello sang
    If you are using Bitrix24 self hosted with rest api enabled then you are able to use the plugin. On "fresh" versions of Bitrix24 self hosted the REST API is enabled by default if you have a licence. The document is the same for self hosted.
  8. rohit
    Jun 15, 2017
    Dear Andreas,
    I am trying to install Bitrix24 in our self hosted version, can you please guide me how to use it and installed in Selfhosted version.
  9. Andreas Paradisiotis
    Apr 7, 2017
    53
    11
  10. rohit
    Jun 15, 2017
    Thanks Andreas,
    for you quick response, do I have to pay extra charges for 3cx pro ?
  11. Andreas Paradisiotis
    Apr 7, 2017
    53
    11
    If you want to use integration plugins you need a PRO license for the pbx . No extra charges
  12. rohit
    Jun 15, 2017
    How to get Pro License, guide me
  13. Ingo Bergmann
    Aug 21, 2017
    Hi Andreas,
    I've got the same problem with my bitrix (cloud) as sang above.
    Could you guide me too?
  14. Andreas Paradisiotis
    Apr 7, 2017
    53
    11
    Hello Ingo
    Be sure that you select the correct location and you have installed the 3cx app in Bitrix24.
  15. Ingo Bergmann
    Aug 21, 2017
    Hi Andreas,
    yes, I've selected "USA/Europe" (as above) in the 3CX Client.
    And the 3XS App in Bitrix24 is also integrated.
    What else can I do?
    I use bitrix24 in german language.
    There's a problem with the location, since a few weeks. I've send this to bitrix24 and they told me to ask the developers.
    Can it be that my problem is related?
    #15 Ingo Bergmann, Aug 24, 2017
  16. Ingo Bergmann
    Aug 21, 2017
    Here's a screenshot in german language.
    If I select English, the representation is correct and also the access rights are adjustable. However, the integration in 3CX does not work with this setting either.
  17. Andreas Paradisiotis
    Apr 7, 2017
    53
    11
    Hello Ingo Bergmann
    I sent you a pm
  18. Ingo Bergmann
    Aug 21, 2017
    Thank you for your help.
    It's fixed!!!
