Solved Error is 0X0
Discussion in '3CX Phone System - General' started by daveh82, Jan 10, 2017.
  1. daveh82
    Apr 25, 2012
    10
    New to 3cx, I have downloaded and installed the most recent version of the software. I followed the instructions at:
    http://www.3cx.com/sip-phones/polycom-soundpoint-450-550-560-650-670/
    However, I get the following error when the phone is provisioning:
    Config File Error
    Error is 0x0
    I also at one point received this error, but just one time:
    Config File Error
    2345-1200-001.sip.ld
    The phone is now in a continuous loop. Any feedback would be greatly appreciated.
  2. MRM
    MRM
    Dec 21, 2016
    53
    Hi Dave,
    Looks like you have to do a factory reset on your unit to stop the looping.
    Please update the post on your findings and if you managed to solve the issue we would be grateful if you could share it with the community.
    Regards
  3. daveh82
    Apr 25, 2012
    10
    I have reset the phone several times. Using 4,6,8,* Seems to work and reboots. The same problem still persists. This is what the phone does:
    1. Phone powered on (after factory reset)
    2. Welcome Screen (4 seconds to auto boot, etc)
    3. Waiting for network to initialiize
    4. Updating initial application
    5. Checking Application
    6. Loading Application
    6. Running... App = sip.ld
    7. Welcome! Processing configuration This may take a few seconds IP Address 192.16.0.105 Enet: 00 04 f2 c5 18 0b Rev: 3.2.2.0477
    8. Config file error Error is 0x0
    9. Phone reboots and repeats same process
    I have followed the instructions exactly. I would expect firmware needs to be different than 3.2.2.0477 but not sure why this is not working correctly. Thanks.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
  5. daveh82
    Apr 25, 2012
    10
    Okay guys. I thought I changed my option 66 path, but apparently I clicked the cancel button instead of okay button. I changed option 66 and everything worked perfectly. Thanks!
  6. GiannosC_3CX
    GiannosC_3CX Guest
    Glad to hear the issue is resolved and thanks for sharing.
