error message
Discussion in '3CX Phone System - General' started by abelaguilar, Jan 17, 2008.
  1. abelaguilar
    Nov 4, 2007
    94
    I get this error message Can someone help me figure out what this means?
    tact=203@127.0.0.1:5070 / 2 from(wire)
    08:46:55.515 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.0.102:5060 tid=bc034d75f33a9912 cseq=REGISTER contact=203@127.0.0.1:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    08:46:55.515 printDetailedInfo [CM502001]: Source info: From: "3CXPhone"[sip:203@192.168.0.102:5060];tag=2e488a13; To: "3CXPhone"[sip:203@192.168.0.102:5060]
    08:46:55.515 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 192.168.0.102:5060 tid=bc034d75f33a9912 cseq=REGISTER contact=203@127.0.0.1:5070 / 2 from(wire)
    08:46:55.187 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: SUBSCRIBE #any-dn#@192.168.0.102:5060 tid=63546d15d7680f74 cseq=SUBSCRIBE contact=203@127.0.0.1:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    08:46:54.875 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: SUBSCRIBE #any-dn#@192.168.0.102:5060 tid=63546d15d7680f74 cseq=SUBSCRIBE contact=203@127.0.0.1:5070 / 2 from(wire)
    08:46:54.875 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.0.102:5060 tid=7a59305b0f69ed2f cseq=REGISTER contact=203@127.0.0.1:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    08:46:54.875 printDetailedInfo [CM502001]: Source info: From: "3CXPhone"[sip:203@192.168.0.102:5060];tag=8556996a; To: "3CXPhone"[sip:203@192.168.0.102:5060]
    08:46:54.875 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 192.168.0.102:5060 tid=7a59305b0f69ed2f cseq=REGISTER contact=203@127.0.0.1:5070 / 2 from(wire)
    08:46:54.750 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.0.102:5060 tid=dd7fc679b416d214 cseq=REGISTER contact=203@127.0.0.1:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    08:46:54.546 printDetailedInfo [CM502001]: Source info: From: "3CXPhone"[sip:203@192.168.0.102:5060];tag=256f3a7b; To: "3CXPhone"[sip:203@192.168.0.102:5060]
    08:46:54.546 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 192.168.0.102:5060 tid=dd7fc679b416d214 cseq=REGISTER contact=203@127.0.0.1:5070 / 2 from(wire)
    08:46:54.546 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: SUBSCRIBE #any-dn#@192.168.0.102:5060 tid=b317243f01398440 cseq=SUBSCRIBE contact=203@127.0.0.1:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    08:46:54.343 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: SUBSCRIBE #any-dn#@192.168.0.102:5060 tid=b317243f01398440 cseq=SUBSCRIBE contact=203@127.0.0.1:5070 / 2 from(wire)
    08:46:54.343 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.0.102:5060 tid=a524215fd05b1244 cseq=REGISTER contact=203@127.0.0.1:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    08:46:54.343 printDetailedInfo [CM502001]: Source info: From: "3CXPhone"[sip:203@192.168.0.102:5060];tag=220a431a; To: "3CXPhone"[sip:203@192.168.0.102:5060]
    08:46:54.343 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 192.168.0.102:5060 tid=a524215fd05b1244 cseq=REGISTER contact=203@127.0.0.1:5070 / 2 from(wire)
    08:46:53.968 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: SUBSCRIBE #any-dn#@192.168.0.102:5060 tid=dc28d04f703ebf2f cseq=SUBSCRIBE contact=203@127.0.0.1:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    08:46:53.781 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: SUBSCRIBE #any-dn#@192.168.0.102:5060 tid=dc28d04f703ebf2f cseq=SUBSCRIBE contact=203@127.0.0.1:5070 / 2 from(wire)
    08:46:53.765 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.0.102:5060 tid=1e68df214639ee5f cseq=REGISTER contact=203@127.0.0.1:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    08:46:53.468 printDetailedInfo [CM502001]: Source info: From: "3CXPhone"[sip:203@192.168.0.102:5060];tag=e8777021; To: "3CXPhone"[sip:203@192.168.0.102:5060]
    08:46:53.468 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 192.168.0.102:5060 tid=1e68df214639ee5f cseq=REGISTER contact=203@127.0.0.1:5070 / 2 from(wire)
    08:46:53.359 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.0.102:5060 tid=20329e79970c6871 cseq=REGISTER contact=203@127.0.0.1:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
  2. abelaguilar
    Nov 4, 2007
    94
    To me it looks like there is an extension 203 with incorrect credentials, however, I do not have extension 203 .
  3. abelaguilar
    Nov 4, 2007
    94
    sorry disregard last log post. Here is the verbose log when a number does not go through and I get the operator error.
    09:18:58.453 Call::Terminate [CM503008]: Call(13): Call is terminated
    09:18:38.156 CallLeg::eek:nConfirmed Session 151 of leg C:13.1 is confirmed
    09:18:38.015 CallCtrl::eek:nLegConnected [CM503007]: Call(13): Device joined: sip:10000@192.168.0.105:5060
    09:18:38.015 CallCtrl::eek:nLegConnected [CM503007]: Call(13): Device joined: sip:106@192.168.0.5:5060
    09:18:38.000 MediaServerReporting::SetRemoteParty [MS210007] C:13.1:Answer provided. Connection(by pass mode): 192.168.0.105:5220(5221)
    09:18:38.000 MediaServerReporting::SetRemoteParty [MS210001] C:13.2:Answer received. RTP connection: 192.168.0.105:5220(5221)
    09:18:38.000 CallLeg::setRemoteSdp Remote SDP is set for legC:13.2
    09:18:34.984 Line::printEndpointInfo [CM505002]: Gateway:[patton] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4118 4JS4JO EUI MxSF v3.2.8.45 00A0BA0350F7 R3.21 2007-05-14 H323 SIP FXS FXO] Transport: [sip:192.168.0.102:5060]
    09:18:34.984 CallCtrl::eek:nAnsweredCall [CM503002]: Call(13): Alerting sip:10000@192.168.0.105:5060
