Error! Module '3CX.com.OSBjsi'. Error ID 501
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Feb 11, 2010.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    What does this mean?
    17:54:37.187|4420|(0):Error! Module '3CX.com.OSBjsi'. Error ID 501. errmsgTypeError: application.testvad has no propertiesline1linetxttokentxt
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    That is a javascript runtime error: "application.testvad has no properties".
    The VAD represents components as javascript objects. Then, the properties of the component are properties of the javascript object. Here, it seems that you have a component named "testvad", but somehow the properties are not initialized.
    Can you describe what are you trying to do? What kind of component is "testvad"?
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    That was the name of the application.
    But I got the problem to go away after a simple change. I had custom components inside the application which had a period in the name, such as testvad.testcode.comp. When changed to testvad_testcode.comp it worked finally.
    I don't understand why, because I thought I had a different component previously that worked fine with a period in the name.
  4. VAD_Support
    Aug 6, 2009
    690
    Well, that explains the problem. With a period in the name of the component, when the VAD generates the VXML script it tries to create the variable "application.testvad.testcode". That is interpreted by the javascript engine as a variable named "testvad" with a property "testcode". But the variable testvad does not have that property, and that's why the problem appears.
    We had a similar problem in the past with dots in the name of the project. We fixed that some time ago. This is a similar problem with the component, we'll make some changes in the VAD to change that automatically to "_" in the javascript variable name. Until this fix is released, you will have to avoid using dots in the name of components.
    Thanks for reporting this.
    Regards,
  5. Nathan Lang
    Jul 6, 2017
    38
    I am getting the same error: "Error! Module '3CX.com.OSBjsi'. Error ID 501. errmsgReferenceError: N is not definedline1linetxttokentxt". Any ideas? I don't have any modules with 'N' as the name.
