Error on Linux Install
Discussion in '3CX Phone System - General' started by Heath, Aug 25, 2017.
  1. Heath
    Heath New Member
    Aug 12, 2017
    122
  2. smario
    smario Support Team
    Dec 14, 2016
    21
    Issue the following command in a terminal and paste the output of that command here for me to see.
    cat /etc/apt/sources.list.d/3cxpbx.list
    Typo in the file. This can happen for example when copying rich text and ended up pasting it as plain text.
  3. Heath
    Heath New Member
    Aug 12, 2017
    122
    :~# cat /etc/apt/sources.list.d/3cxpbx.list
    deb http://downloads.3cx.com/downloads/3cxpbx//
  4. GiannosC_3CX
    GiannosC_3CX Guest
    hello heath,
    The results of the above command should look like the following screenshot:
