Error on opening Settings -> Advanced
Discussion in '3CX Phone System - General' started by abe1977, Jul 11, 2011.
  1. abe1977
    Jul 11, 2011
    Hi all,
    Ever since i upgraded to 3cx v10 i get the following error message when i try to open Settings -> Advanced
    An exception occured AdvancedOptions Error: Index was outside the bounds of the array
    This error is presented in a popup box both on the Windows Management Console and via the Web Management Interface
    I can close the box by clicking OK. However i cannot change any values because when i do and try to save (by clicking OK or Apply) i popsup antoher error box saying The specified call history inteval is invalid.
    I am however not able to change that value, or anyother in the Custom Parameters tab, because this tab shows NO options at all.
    Does anyone have any suggestions how to fix this???
    Look forward to hearing from U
