Error: OutboundRule
Discussion in '3CX Phone System - General' started by ed1976, Apr 23, 2013.
  1. ed1976
    Feb 2, 2012
    I install the service pack on 3CXv11, thereafter all outbound rules have routes value - BLOCK CALLS.
    I get the error message:
    An exception occurred CreatedOutbandRule Error: OutboundRule
    when I try to change the outbound rule or create a new.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    This might be clients that are not turning off MyPhone (logging out) when they leave for the day.
    I don't think you can do anything except to log off their computer. If I recall, it happens when the server is recycling the 3cx services.
  3. kevin
    kevin Member
    Nov 23, 2006
    316
    @craigreilly
    You can try Backup + Restore - maybe this clears out some database inconsistency which has appeared.
    You can also try to delete all outbound rules and start creating from scratch.
  4. ed1976
    Feb 2, 2012
    I reinstalled 3cx system and restored the backup configuration.
    Now it works correctly.
    The problem was that the original was installed from beta version 11.
  5. craigreilly
    Feb 1, 2012
    2,962
    180
    ding ding ding.
