Error registering to asterisk server
Discussion in 'Windows' started by rsvargas, Dec 22, 2010.
  1. rsvargas
    Dec 22, 2010
    I'm trying to configure the 3CX phone to use it with an Asterisk server. But I'm receiving "Destination not found" error.
    This is my profile configuration:
    Code:
    [Profile0]
    Name=Vargas
    Enabled=1
    CallerID=Vargas
    AuthUser=2916
    AuthID=2916
    AuthPass=myPassword
    PBXAddr=169.254.1.200
    PBXRemoteAddr=169.254.1.200
    PBXVoicemail=
    ServerProxy=169.254.1.200
    DtmfRFC2833=1
    DtmfInband=0
    DtmfSipinfo=0
    DtmfPayload=101
    SipTransport=0
    RegistrationTime=2
    Codecs=PCMA;PCMU;GSM;
    VideoCodecs=H.263 (ffdshow)
    VideoFormats=QCIF;CIF;SQCIF;CIF4;
    LocalPBX=1
    RTPTransport=0
    ProvisioningURL=http://
    UseTunnel=0
    UseProxy=0
    TunnelPass=abc
    TunnelRemAddr=169.254.1.200
    TunnelPort=5090
    PBXPort=0
    STUNServer=stun.3cx.com
    AutoProvisioning=0
    VoicemailConfirmed=0
    SoundVolume=0
    CLSID={4E74C3EF-AB54-4179-A45C-1F72D847B8AC}
    This is the REGISTER message sent to the server (got it using wireshark):
    Code:
    REGISTER sip:169.254.1.200:5060 SIP/2.0
    Via: SIP/2.0/UDP 169.254.1.38:51490;branch=z9hG4bK-d8754z-ad16325069569a69-1---d8754z-;rport
    Max-Forwards: 70
    Contact: <sip:2916@169.254.1.38:51490;rinstance=60d51e7c4b108961>
    To: "Vargas"<sip:2916@169.254.1.200:5060>
    From: "Vargas"<sip:2916@169.254.1.200:5060>;tag=8566bb15
    Call-ID: ZGIwMTkyNjAwYmY5NTdjNTdiYjE3NmUwYjBjODY1NTQ.
    CSeq: 1 REGISTER
    Expires: 120
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Supported: replaces
    User-Agent: 3CXPhone 5.0.14900.0
    Content-Length: 0
    This is the responde from the Asterisk Server:
    Code:
    SIP/2.0 404 Not found (unknown domain)
    Via: SIP/2.0/UDP 169.254.1.38:51490;branch=z9hG4bK-d8754z-ad16325069569a69-1---d8754z-;received=169.254.1.38;rport=51490
    To: "Vargas"<sip:2916@169.254.1.200:5060>;tag=as7f3eb55f
    CSeq: 1 REGISTER
    Server: My PBX
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
    Supported: replaces, timer
    Content-Length: 0
    comparing with X-lite REGISTER packet:
    Code:
    REGISTER sip:169.254.1.200 SIP/2.0
    Via: SIP/2.0/UDP 169.254.1.38:56360;branch=z9hG4bK-d8754z-6816ecbab5aed950-1---d8754z-;rport
    Max-Forwards: 70
    Contact: <sip:2916@169.254.1.38:56360;rinstance=4af49b09ca2d791e>
    To: "Vargas"<sip:2916@169.254.1.200>
    From: "Vargas"<sip:2916@169.254.1.200>;tag=fb15bf30
    Call-ID: NzYzY2Q4YmNkZmQ0NjU3ZWUyMjZmNGJkMWZjZGE2YzQ.
    CSeq: 1 REGISTER
    Expires: 3600
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
    User-Agent: X-Lite 4 release 4.0 stamp 58832
    Content-Length: 0
    which the server responds with:
    Code:
    Max-Forwards: 70
    CSeq: 1 REGISTER
    Expires: 3600
    Content-Length: 0
    and a 200 OK follows...
    Code:
    SIP/2.0 200 OK
    Via: SIP/2.0/UDP 169.254.1.38:56360;branch=z9hG4bK-d8754z-6816ecbab5aed950-1---d8754z-;received=169.254.1.38;rport=56360
    To: "Vargas"<sip:2916@169.254.1.200>;tag=as71dcd7e0
    CSeq: 1 REGISTER
    Server: My PBX
    Expires: 120
    Contact: <sip:2916@169.254.1.38:56360;rinstance=4af49b09ca2d791e>;expires=120
    Date: Wed, 22 Dec 2010 14:20:56 GMT
    Content-Length: 0
    Seems to me that the only difference is that the 3CX register message includes the port in the "To:" and "From:" fields... Is there a way to fix this? Or is there a know workaround for the 3CX soft-phone to work with asterisk?
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,399
    79
    On the machine with the PBX go to Start > Run > cmd
    and inside the CMD window, type ipconfig and post here what exactly it says.
  3. rsvargas
    Dec 22, 2010
    My windows is in Portuguese, but I think everything should be in the same place, but to sum up:
    My IP: 169.254.1.38
    subnet mask: 255.255.255.0
    gateway: 169.254.1.1
